Sounds good mate id be interested to see the logs see what difference its made
Strange about the gauge though lol
I was thinking it could be the slider with the rod on not touching the circuit board but ill be leaving it till the weekend now
Ill post them up on my stage 2 logs thread so keep an eye out..
No it cant be that the slider is spring loaded onto the board..
I think mines just getting stuck somewhere.
Well mine wasnt working because I forgot to bridge the 2 black cables that connect to the circuit board.. Your is an LCR one though isnt it?? so that wont be your problem..
Does your guage beep like you have no fuel?
Yer i got an lcr one now so wont be that.
It doesnt beep no its just sat on empty and doesnt move at all
Im sure its the float tbh
When i removed the float and mini circuit board with the slider on from my old pump i accidentally bent the rod a little when i took it off, so when i clip the rod on its pulling the little slider up so the mini pins on it arent making contact on the board.
Gonna take it out tomorrow and sort it i think.
Yours working now then?
Yeah its working as in electrically connected and it beeps saying there no fuel.. but I reckon iv bent mine too coz its reading like 2mm on the guage for 10L of petty.. out AGAIN tomorrow lol grr and I thaught it was going to be easy lol
Just done mine too mate
Was exactly what i thought, the springy bit had come off the slider so it wasnt making contact with the board.
All sorted now and the gauge is working fine :)
Yeah I dont fancy doing that again, such an annoying fiddly job! Glad its sorted now though mate, Iv had a busy day today of sorting out my rattly exhaust and taking off my intercooler to stick it on ebay.
I have 2.5", it's well up for the job of BT power so K04 hiybrid should be fine too :)
You want to look for surface area, that's what's going to improve cooling more than anything.
Yeah I know 2.5" is the perfect size but I was going to get one of the toyosport ebay coolers like berg has, and they come in either 2.25 or 3".. bearing in mind I will be useing 2.5" pipeing I think it would be better I step up to 3" rather than step down to 2.25"..
If you take a look at some of berg's pics the cooler is huge so no problem with surface area :D
Berg, how much was your LCR pump?
Fancy giving me a hand fitting one?
Wanna swap the wheels back, my brakes dont fit behind the super's, oddly they would fit behind the team dynamins haha! typical hey?
Ahh right I see well if you're set on that cooler I would go 3" and use a couple of 3"-25." redcucers on the cooler inlet/ outlet.
sorry for hijack Berg!
My pump was £60 delivered from a breakers
I dont mind lending a hand, ive swapped then in and out loads of times in the last week lol
I would actually consider the swap but ive just had 4 brand new toyo t1r tyres put on them 2 weeks ago lol that is **** luck though!
