Few new things to fit
First off a stack Wideband gauge kit
This looks a neat bit of kit, AFR and Lambda displays plus abilities to log the data etc
Omp front lower strut brace for ybracing
Omp rear upper strut brace also from ybracing
S3 fuel pump also here, fitting all this weekend hopefully!
nice bit off kit mate got a link to there web site
Right got a new fuel pump coming tomorrow
Ive sent the S3 one back as it seems to be fooked!
Bought one from a 54 plate LCR 225 so hopefully better luck with this one :D
LCR pump fitted this morning :D
Managed to do the complete swap in about 40 minutes this time
Swapped the floats over, my fuel gauge isnt working now though :( im thinking the slider isnt touching the circuit board so ill sort that at the weekend
LCR float/sender removed
Unfortunately my fuel tank was full lol so was a bit messy
New pump in
Just been out for a blast and it actually feels alot better
Its almost like before it was kind of sluggish as it now seems to pull better on boost
Hopefully this was my problem fingers crossed
Sounds good too, never had so many pops and bangs letting off throttle before lol
well I havent personally tried it myself but I have heard disconnecting it does work.. not sure how long you have to leave it disconnected for though..
Out of interest how much did all your piping for you intercooler cost you in total?
Might give it a go and see what happens, 10 mins is enough iirc
The pipework kit was about £70 from ebay
Everything together including the pipework, intercooler, forge map tube, t-bolt clamps, washer bottle etc etc came to around £280
I'd leave it for as long as possible just to be safe.
Cheers, Im thinking of having the same setup just with the 3" cooler but use 2.5" pipework.
Well worth the money mate imo
These coolers are rated upto 450bhp iirc, i think philw is using the 3" version, bit of a tighter fit as the are 80mm thick
I havent got an aircon rad so it should be fine.. and yeh for £80 you cant really go wrong
Just fitted mine too mate, pulls alot better all the way through the rev range dont it. And also getting a few pops and bangs on the initial overrun too.
Im gunna do some logs and see if its made any difference.. (probably not haha!)
Also got the same problem with the guage not working :(
