cheers for most of the comments guys!
to Number86...
I'm not a chav who drives about with his fogs on, I just feel the need to turn my fogs on when I am in areas with absolutely no street lighting what so ever (parts of dual carriage ways, country lanes etc etc) and as soon as i am back into an area with good lighting i turn them off! you will not catch me driving with them on in town I can assure you of that!
now back to the other replies!
RikH... unfortunately I haven't got a pic yet of the ballasts fitted!
Il go take some in a bit if I have time!
BCM... no but il take a pic, looks fine and spot on though!
Si... i had to drill a hole either side for the brace... remove the carpet and you will see! and I used four 8mm nuts/bolts with washers.
with regards to strutbacer.co.uk yes rob (moffmeister) had bad dealings with him, but despite this I took the risk bought from his ebay site as the brace was £55 delivered as opposed to £83 and It came within 2 days, so as far as im concerned, great service!
lastly RobDon... I see I mounted mine more snugly than you (i did search for pics of yours but lucky couldn't find any!
) and after playing with the brackets for about 45 mins decided the way I fitted it was the best way. I did try your way but I thought my way was better as its tucked out of the way much more. strength wise it shouldn't make any difference as the surface area of the brackets which is in contact with the car is the same fitted either way!
to Number86...
... we tested them last night and Craig said they did not blind him at all!I only use them when on the motorway at night time in poorly lit areas (i.e. when there are no motorway street lamps or down country lanes etc)
