Nice thread.
Just one question before I order my set of H7 4300K HID's...
Why do prices vary so much? I think I saw a conversion kit from Diane-Shop on flea bay for about $60.
Then there is a kit on hids4u for about £100.
open up the black plastic screw at the front of the washer bottle and put the mount under that! if you want to take it out pull off the pipe at the washer jets and spray it in to a container. if you take it off it would be wort your while washing it out as they can get stale! the side lights should just pull out! try use a long nose plires to pull them out!
As above so do mine either get them checked elsewhere or turn them up yourself parked against a wall.
My HID's light up road signs perfectly.
nicked from ebay, this now shows 5000k. i've blown a normal h7 bulb and thinking about hids..... hmmm![]()
If/when mine ever need replacing i'm going either 4300k or 5000k
