thanks for the comments lads she is getting there now brembo refurb next as they have just started to fade then the big service
Hey Harty, I am gonna go at installing the mbc tomorrow as I am consistently hitting 1.8bar of boost on 3rd gear runs today.
Is there a default setting on the mbc or do you just keep turning it until you have the desired boost.
Also do you know the internal ID of the pipe coming from the charge pipe to the n75. I wanna keep the oem.
Also u should check out my RR, just finished a wmi install, it may interest you.
Engine bay looks brilliant mate
As said looks great (Y)
what manifold you ordered mate?
$hit I installed it before I read your response with the soft spring, looks like it will be coming off again tomorrow
The WMI is awesome, inlet temps are consistently down and low, I added about 9* of timing with the WMI but this was only added on the upper side when under load as opposed to lemmiwinks which adds it across the board, I had it on the rollers and we logged 0 pull across the cylinders so more timing was possible but just not advised, this was on a 50/50 mix, EGT's are down also, the car pulls like a train now regardless of the weather, the inlet Mani fells cold after a spirited run, along with more pops and bangs from the methanol
Believe it or not my exhaust is also super clean with no soot build up, I guess it's from the water being injected but it's not something i would have thought of.
Ordered rods/bearings/manifold and hybrid today, getting all the bits ready for and rebuild/upgrade.
Also how long did it take before the soft spring started to act up, I have mine set at 1.6bar
what manifold you ordered robbie and loving this build thread, i was going to get and electric boost contol but think will go with the forge one your using :0)
yeah i did the badge myself mate the only reason i wrapped it was because when i painted it i got fed up with the stone chips right pain in the arse to keep painting as for the wheels i really love the coulour and when the sun shines there even better the cost 280 notes they were chemically striped, all marks taken out,powder coated, then laqured with a metalic flake they carry 12 months warrenty which is good, did you go to inters on the scn stand
Yeah i was in the inter SCN stand, i thought i reconized your car.
looks awesome mate, very nice... were did you get the front light guards from?
