Right got one question guys i bought this LCR Maf a while back i was just wondering is it missing a part and if it is will i need it when i put it on for hybrid or will it be ok without it? Also will i need to swap the connectors round or is the LCR Maf good to go the way it is?
You can see the part im talking about when i compare the
Ibiza Maf to the LCR Maf
Ibiza
LCR
Also made a start on removing the turbo all ive got to do is disconnect downpipe and oil and coolant lines then hey presto
if only it was as easy as that
Also took my tip off to find it had a tiny hole in the side where it was rubbing on a clip which must of been causing it to collapse and hit limp mode (i hope) so thats another £130 for a tip
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
