1st drive today for 8 week! :D // but wasn't all plain sailing :s
Seatmann
Rough around the edges
Sep 16, 2010
5,575
10
Scotlanda
Now that sounds logical, if a relay is bad it can heat up and fail, I see it a fair bit on the tdi cars with the 109 relay for the ecu, hopefully it is that.
Aug 22, 2008
3,221
cannock
my other half first changed the crank sensor and then it wouldnt start so she had to go into a garage to get another one fitted i have been told they are very tempremental , and no deffinatley no we dont want any more dying, to be honest ime lucky to have a vw specialist 2 minutes from my house which in times of need is a great help
hope you bith get them sorted soon guys :)
old 'uns
Modern Life is Rubbish...
Mar 20, 2003
1,627
walsall
Visit site
Update!!! Cars in bits at garage lol :p they've order the actual distributer to see if that solves the problem... If not it could be the cylinder head :/ :/ fingers crossed guys it's not the head...
your symptoms are electrical, heat causing breakdown. usually coil pack, relay, crank sensor, ignition lead from coil to distributor & hall sensor in dist.
relay been replaced?
if the garage thinks it's the cylinder head, pick up all your bits & push the car as far as possible from their little fingers.
Ads_Vag
If in doubt... FLAT OUT!!
Feb 23, 2011
479
Warrington
www.extremebhp.com
The electricals are fine they've checked um :/, it's had new coilpack, had new crank shaft sensor, so there changing the actual distributer.... & I know the garage used um plenty of times there good :) But the pressure on the head is perfect but that's when it's cold, can't check it when it's warm because it won't fire up...
Seatmann
Sep 16, 2010
5,575
10
Scotlanda
Opposite way round bud in my experience, this is nothing like a head problem, it's either spark or fuel and more than likely a bad relay somewhere. I've seen loads of bad heads over the years and never had anything like these symptoms, sounds totally bollox if you ask me. I'm a bit concerned about this garage you're using, it's begining to sound like they don't know what they're doing.
Ads_Vag
Feb 23, 2011
479
Warrington
www.extremebhp.com
nope.
lost any water?
spark plugs wet with water?
coolant tank pressurised?
probably more but still say electrical.
Well I'm constantly filling the water up like every 2 week lol :/
I've used this garage before tonnes of times & never a problem.....
