Now that sounds logical, if a relay is bad it can heat up and fail, I see it a fair bit on the tdi cars with the 109 relay for the ecu, hopefully it is that.
Cheers kezz, I'll let the garage know to check that just incase
fingers crossed mate i was just seeing what i could find out for you
Cheers we dont want another mk2 dying do we :/
Nope, trying to save mine now too, as after my failed attempt to change my crank sensor, my car now won't start
Update!!! Cars in bits at garage lol they've order the actual distributer to see if that solves the problem... If not it could be the cylinder head :/ :/ fingers crossed guys it's not the head...
your symptoms are electrical, heat causing breakdown. usually coil pack, relay, crank sensor, ignition lead from coil to distributor & hall sensor in dist.
relay been replaced?
if the garage thinks it's the cylinder head, pick up all your bits & push the car as far as possible from their little fingers.
nope.
lost any water?
spark plugs wet with water?
coolant tank pressurised?
probably more but still say electrical.
Opposite way round bud in my experience, this is nothing like a head problem, it's either spark or fuel and more than likely a bad relay somewhere. I've seen loads of bad heads over the years and never had anything like these symptoms, sounds totally bollox if you ask me. I'm a bit concerned about this garage you're using, it's begining to sound like they don't know what they're doing.
Well I'm constantly filling the water up like every 2 week lol :/
did you mention this to the garage at the start?
..or in this thread at start of problems.
eerrrrrmmmmm....not normal to keep throwing water in
