Today my Leon gets a well deserved rest.
Had to be pressed into daily service for the past 4 weeks while the “reliable” Volvo V70 was away having some major engine surgery done.
As usual the Leon did everything it needed to do. Yes it’s a bumpy ride and Yes the kids were squashed in the back but Its been nice to have a change for a bit.
It now needs a good wash and hoover before it goes off on its holidays to stay on my parents drive while we have an extension built.
Not risking leaving it on our drive with deliveries, skips and scaffolding arriving soon. Lol
After spending a while trying to remember how I got the bonnet release handle off (there are two screws, not one) I finally got this installed. Seriously, this has bothered me so much for years, and I'm so happy I've got a replacement in there.
One of these days I'll get round to putting the new pedals in too.
You can see how cracked the old one was. How many extra horsepower do you think this'll make?
I still got the old set I took out and master cylinder so you could referb them and then fit them to yours
You know what - that might be what I need. Not so much the pedals, but the master cylinder. Still having trouble with my brakes and if it turns out to be the master cylinder seals, I'd prefer to rebuild and bolt the replacement straight on... I'm seeing a VAG specialist on Tuesday for the diagnosis so will keep you posted...
In other news, I finally got some of these ordered. They're going for £21.99 on eBay from Euros, so will fit them when I pull the undertray off to do the Mr Muscle turbo clean. Any recommendations on whether to do the lower engine mount one or the insert at the same time? The lower engine mount looks like it can be a pain to do if you haven't got something to press it in with - does it make a difference? The insert looks much more straightforward but of course, I have no idea which one I need...
After a problem with wiring I had to replace my light switch back to standard
I’ve had auto headlights for a couple of years but had problems with the dimmer - I’d used the switch surround from mk5 golf - but today decided to make the larger auto switch fit into the standard surround.
A few passes with my dremel seen it slide in
Will get a pic of it fitted back in 2moro
Reactions: bigT's lcr
The worst bit about the dog one mount is taking it off - the bolts connected to the chassis tend to snap if your not careful
Well, that's given me the fear. Luckily the car's always had the undertray on, which might just have kept things intact under there, and I haven't seen much in the way of corrosion when I've been under it either. Fingers crossed if I just soak it in PlusGas before I do it, they'll all come out OK. That said, I have heard stories about people just touching the bolts with a socket and they sheer off...
I'll be doing the PlusGas, heat, wiggle back and forth, tighten and untighten, more PlusGas, more heat method then.
Such a worthwhile mod, really improves the feeling of the car. Although i've had my dogbone off twice and it was no problem, as always plenty of penetrating spray.
Reactions: iammooks
Tried to get rid of the remainder of the stock CAI, the bit that is fixed around/behind the headlight on the passenger side.
Took my battery out and everything but still cant figure out how to remove it!!! Any know how to get this sucker off?
Fitted some mk4 4 golf areo wiper arms and blades got them off old flee Bay for the price of 26 notes they sit so much more flush then the oem. Nice now cheap mod to do.
Reactions: iammooks
Those blades clear the edge protector nicely - did you cut the nearside one down or is it a different size? I've had those wipers for years and the blades need replacing, but I've heard that if you buy shorter ones, they still foul on the side.
Thanks and yes I cut them down about an inch, I think you have to do this sadly but I have found some 18 inch ones on ebay that are side pins that are for the polo so maybe they will work with no cutting needed as the ns is 18 inch when i measured it, but these arms look so much more tidy can't believe the price they are new, and these were in mint condition.
Reactions: iammooks
I got a set ages ago and after a couple of sets cutting the wiper I bit the bullet and cut an inch out the passenger arm then getting it welded - no more cutting down wiper blade
Reactions: iammooks
As promised
Car has started making a wonderful dry creak from between the foot wells and engine area when pulling off and stopping slowly. No idea what it is but it’s not the track rods of drop links, also:
-recently changed arb bushes to oem ones with copper grease
-steering rack to subframe has two bolts snapped (been that way problem free for couple of months)
Take your guesses on what it is?
AUDIO
