Manic172
But arnt they a bit bigger tho...Its a round thing. Bit like a polo but less minty.
I got some peddles if you want them
The pedal box for your race car?
I still got the old set I took out and master cylinder so you could referb them and then fit them to yours
The worst bit about the dog one mount is taking it off - the bolts connected to the chassis tend to snap if your not careful
Well, that's given me the fear. Luckily the car's always had the undertray on, which might just have kept things intact under there, and I haven't seen much in the way of corrosion when I've been under it either. Fingers crossed if I just soak it in PlusGas before I do it, they'll all come out OK. That said, I have heard stories about people just touching the bolts with a socket and they sheer off...
I'll be doing the PlusGas, heat, wiggle back and forth, tighten and untighten, more PlusGas, more heat method then.
Fitted some mk4 4 golf areo wiper arms and blades got them off old flee Bay for the price of 26 notes they sit so much more flush then the oem. Nice now cheap mod to do.
Those blades clear the edge protector nicely - did you cut the nearside one down or is it a different size? I've had those wipers for years and the blades need replacing, but I've heard that if you buy shorter ones, they still foul on the side.
After a problem with wiring I had to replace my light switch back to standard
I’ve had auto headlights for a couple of years but had problems with the dimmer - I’d used the switch surround from mk5 golf - but today decided to make the larger auto switch fit into the standard surround.
A few passes with my dremel seen it slide in
Will get a pic of it fitted back in 2moro
