My set upand also my work place
I was about to say - if it involves lifts or an inspection bay, you can bloody well do one.
What's the matter? Can't jack your car up like the rest of us? Lazy beggar...
Okay so,
I just ran out there and jacked it up and checked for play Top to bottom / laterally and none what so ever.
Does that help narrow it down? Guess it’s not the CV outer or the ball joint...
I have to jack up a van today to give it a full service pull the rear brakes out and clean and grease them adjust the rear shoes and clean and oil them remove the front brakes and replace them clean and grease everything up then do the timing belt and water pump
Ok is there any movement in the engine can you move it at all
Do you get any other noises when driving? Or is it just set off when you get that noise
I not got a car lift I can use but ....View attachment 19309
Just doing a clutch ...saves laying on my back
I could off done with that ramp the other year I had to do a clutch on a 7.5t truck on my back not fun and very heavy
Going to be sorting my brake master cylinder soon - can anyone confirm that the size flare spanner I need for the brake lines is 11mm? I went out to check on the car and for some unknown reason, my spanner set jumps from 10mm (which was too small) to 13mm (which was too big) so couldn't make sure.
While I'm at it, I'm thinking about changing my brake lines to braided hoses. Is it worth it? If I'm going to be bleeding the system anyway, it's something I may as well do all at the same time. The existing lines are fifteen years and 160k miles old, and if it actually improves braking, so much the better...
Yeah change them...... new shiney is always good idea..Going to be sorting my brake master cylinder soon - can anyone confirm that the size flare spanner I need for the brake lines is 11mm? I went out to check on the car and for some unknown reason, my spanner set jumps from 10mm (which was too small) to 13mm (which was too big) so couldn't make sure.
If I rebuild master cylinders on something milder always worth some new lines. Last thing you want is an old one to collapse when you’re out and about. Happened to me on a motorcycle. Now she’s got braided lines.
