As Dave says, you'll get everything you need to fit, but more importantly (IMO), if it goes wrong, you have a company you can go back to who will sort you out. Although Ebay cores are alot cheaper, who do you turn to when it goes wrong?
cars in the garage as well speak getting itself a new clutch :D
I've asked them to take photos, and the guy wrote it on the worksheet which I signed. No doubt they will either take 1 of the old clutch only or just forget though
well aslong as you dont take it to Holders!! car was in there 5 times to try and find the fault in my glow plug loom.... me and dave olin plugged it into vagcom and found the fault in about an hour!
Muppets!
yea dollin has his uses :p or rose as it is now!
Mines in at Taunton Seat. The guys in there are friendly and helpful enough. Although they did say my front pads were 80% worn on the service. I had a look at the weekend...they only looked slightly worn from new! was absolutely loads left on them. If thats what they are at 20% they must be about 2cm thick new!
dont really care what the others think tbh lol
not got car back yet as i didnt get back from work until after garage had closed, gonna get it tomoro as i have a half day :D
what a waste of a half day lol, you should use it on friday and have a longer weekend! :p
I may have to order some stickers too, seen as I spend more time on here :lol:
im sure rob will have some at the next meet ;)
really considering Anthracite wheels after seeing them on filbros and jonnyjonjons lcr's as they do look good. with the roof and spoiler done as on filbros, it looks really good. Tough choice as i like the standard silver to :think:
best get the rest of you MOT bits n pieces done first eh? :p
new exhaust is ordered, so in theory is should be fine (maybe just need to change the rear indicator bulbs)
The dealer took some photos of the clutch when they took it out, will pop them up later. They printed them off, and emailed me them which was helpful :) The customer service at Taunton Seat so far has been really good. very friendly and helpful (although their technicians arent afriad of trying to spend your money)
photos of the old clutch, a little worse for wear lol...
Apparently part of it had disintregated. They said they are going to keep a copy of the pics as its the worse they had seen
this is what the job sheet said
Attend to clutch pedal poor and gears difficult to select. removed the gearbox and found the clutch plate has fallen apart (friction material disintegrated thus causing scoring to pressure plate surface)
no wonder when it went it stank of burning oil lol
