Yes... some confusion if it's a mib2 high you bought then there is no map card, the maps are stored on an internal SSD not map card. To populate that you need this file. It's the latest, June 2025 release.
Seems to be from the forth week in April, although it tends to be up and down a lot with load issues. But down completely this time. The mib hobbyists have invested a lot of time in it and the mib helper web site links to it as do many boards. There might be other posters who are in the Telegram...
www.seatcupra.net
The resource section see below Mib2 High heading gives you a blow by blow account of the unit. You should see the life long fecs. They unit also has a juke box. If yih stab away at the media button it will show you jukebox. That's a mib2 high. Only the mib2 high has the jukebox on it.... ssd space used for sound files.
This resource is applicable to all Seat navigation systems plus other Vag brands which are MIB2 / 2.5. It is built from the knowledge base on the Leon forum from a long running thread which has the advantage of tracking the twists and turns over...
www.seatcupra.net
You need a 32gb standard sd card, fat 32 to upload the maps from that link I gave you. Should take 60 minutes on and above with the engine running... once triggered i if you do have a mib2 high. Here they may be talking about the cid but not on a high unit. So first do your checks that it is a mib2 high installed otherwise called a Seat Plus... in Seat lingo. Failing that if it's a doctored mib2 standard then a 32gb standard card in the slot with this on it should work but you need to be hard headed about what you have.
Latest mib2 standard maps:
Yes copy and paste between devices. Move is only if it's on the device. It's fallen into no man's land. Deleted from the card and not moved. Move we'll read as cut and paste. Generally not between devices and that's two devices.
www.seatcupra.net
