Tell
Westindieman
87
9
Back to the cluster size 4096 and whether the cards works with the original map copy. Then did you update to the latest 480 firmware. Jury was out on whether you needed that.
I didn't update the firmware, ive just read through the update firmware section (2 pages) and don't see anything relevant to my 2013 Seat Leon
Tell
The 480 firmware may still be on this link else ask @Daz3d
The jury was out on whether you need the very latest mib1 firmware for it to work. 480. Depends on what you are on. There was some discussion about the upgrade. As yet nobody has said its messed it up. It might be the root of the ambiguity of why people back in 2017 / 18 could update and others couldn't.
Reactions: Westindieman
Westindieman
87
9
I have the update, do I unpack the rar file, also is the process in the youtube video the one I should follow?
Tell
You should find the procedure here
It's important to keep the car running since any loss of power during a firmware update will mess the unit up. Some say battery charger. The main thing is keep the power on. Probably youtube videos as well.
As for clearing the error after I don't think you need to. You need a coding device for that and that logic to generate the clear code. Anybody mib1 updated the firmware and was in necessary to clear the "error". The error is a flag set to say this unit has been updated. It's a Vag thing.
Anyhow if 480 is important you will have done that as well.
Westindieman
87
9
Thanks for finding that, my searches don't seem to find what I need. I'll do the update tomorrow but have to say I'm very nervous about it and not even sure it will fix my issue
Westindieman
87
9
Other people have done it on the thread. You need a fully charged up battery and you can't interrupt the process.
Equivalent Skoda thread
15 reboots... :unsure: . So be prepared for that. Unlike Windows that does it in a couple.
Its done mate thanks, took about 50 minutes this morning. The cars at garage for MOT right now so I will recheck the updated nav disk later and see what I need to do to clear any error messages.
Westindieman
87
9
So I still haven't got it working with the updated disks. To check the MIB2 disk I restored my MIB1 nav onto the new MIB2 card and tried it, that works OK. Checking the process I did before is correct, I just over write the disk with the updated map file then edited the DBinfo file.
Tell
Yes that should work. That is what everbody else did. Notepad editor. Keep the spaces in the partcode you edit in.
DaveS
50
31
When I updated my system I found it better to edit the DBinfo file on the PC before copying files to the card. Editing it on the card directly did not work.
Tell
I'd edit it on the PC then copy over. Some small step, error missing somewhere. It hangs on the Audi part identity of the original card in the two places it's declared. So if it's not seeing that it won't work. We also used the identity of an older release on the thread as well when the original card got lost by one person as I recall provided by @Daz3d ... on the thread. Old mapcare trick that you can put in an old card and it works. This case an older seriel part number.
As I said before when swapping cards after changing them you must do the long hold on the on/off till you see the splash screen comes back up. If you don't then it will have in memory the identity of the previous card it's read, you need a full re-read. Same is true with the mib2 SD map cards. After 20 mins you don't need to do that. Perhaps that got missed out. Edited card in slot, force reboot.... & the card should just contain the map.
Jun 20, 2024
30
Sorry if this problem has already been covered, but I recently bought a MIB 2 High retrofit kit from EastYorkshireRetrofits and after fitting it the sd card with the navigation database from the old unit is recognized as “containing the navigation database”, but opening navigation shows that the navigation database is missing.
I contacted them and they said the unit is patched with CID turned off so it should be as easy as downloading the navigation data from Seat and putting it on the SD card, but that didn’t work too. Has anyone ran into such a problem?
Tell
Yes... some confusion if it's a mib2 high you bought then there is no map card, the maps are stored on an internal SSD not map card. To populate that you need this file. It's the latest, June 2025 release.
The resource section see below Mib2 High heading gives you a blow by blow account of the unit. You should see the life long fecs. They unit also has a juke box. If yih stab away at the media button it will show you jukebox. That's a mib2 high. Only the mib2 high has the jukebox on it.... ssd space used for sound files.
You need a 32gb standard sd card, fat 32 to upload the maps from that link I gave you. Should take 60 minutes on and above with the engine running... once triggered i if you do have a mib2 high. Here they may be talking about the cid but not on a high unit. So first do your checks that it is a mib2 high installed otherwise called a Seat Plus... in Seat lingo. Failing that if it's a doctored mib2 standard then a 32gb standard card in the slot with this on it should work but you need to be hard headed about what you have.
Latest mib2 standard maps:
30
The old device was probably a standard navigation system, right?!
Yes it was standard.
weirdly enough EastYorkshireRetrofits never mentioned that. They even encouraged me to use the old original SD card with the nav data even tho I said it didn’t work. Thanks for the reply tho, will try that as soon as possible!
Jun 20, 2024
30
Unfortunately it didn’t work. I formated the card in ExFat as per VW instructions. Inserted the card and the car recognized there’s an update file on it, but opening navigation still shows “the navigation database is not available”. Going to hidden menu and clicking on Software update shows “Error: Variant conflict Medium: Device doesn’t support this (MainUnit: variant)”.
Tell
Feels like one for @East Yorkshire Retrofits that sold it.
There's nothing wrong with your old SD card, which is why we didn't mention it. The unit is configured to work with any SD card you fancy using. I've sent you an email
We did say to replace the navigation data contained on the card
It's MIB2std, we do NOT sell MIB2high
Reactions: Tell
Do not update the infotainment system, we ship every system on the latest available software. The map files stay on the SD card, which stays inside the infotainment unit
