Probably the old Apks are being blocked on the Android update cycle of versions. There is a way of sideloading old Apks via the developers menu and plugging in your device (Android phone) into your PC / laptop and installing it that way. I did that with some very old apps on Irish birds and Butterfly identification ?. They hadn't been rewritten from Android 5. Into Android 14 and migrated to Android 15. They were definitely not rewritten for later versions of Android. Was an Irish person's pet project on identification. They get the same as us but less diversity so UK apps would work for identification...
I'll look the commands up and edit in later. Its ADB plus a specific command put in for the purpose which skips the block. This would be usefull where you have the old modified app, think it was Android Auto which people had that supported Mirrorlink. It is Samsung Galaxy fablets I use. Worth a try if you have something that worked but can't install on a newer version of Android.
It's this one:
Run the following command in your terminal/command line window:
adb install --bypass-low-target-sdk-block FILENAME.apk
From XDA forum. I guess it works for Android 15 as well. It's a more slick way than editting the manifest.
However if it's an older model than Android 14 you might have to edit the manifest. That fools it to think its a new app. That bypass command came in later to be helpfull to developers.
Thanks, I'll do some research, it's Android 10 on my phone
You need the mib2 firmware thread that sits in the Leon 3 area. Same for all Seat / Cupra mib2s. Picking off the correct unit
This is the map update thread, not firmware update thread.
link is not working
TrYED p94 for mstd
this is dbinfo from original card
PartNumber1="-----------"
PartNumber2="5G0919866E "
PartNumber3="5E0919866E "
PartNumber4="5F0919866E "
PartNumber="-----------"
ApplicationSoftwareVersionNumber="0034"
SystemName=" ECE 2013/14 "
p94 refuse to work
TrYED p94 for mstd
p94 refuse to work
That's mib1 you need to follow this
Follow people's success with this. Take a copy before you start off.
I referenced that in the resource:
In the end nobody to my knowledge hasn't got it to work. Eg. Everybody has had success eventually.
@Daz3d posts that one and after contain the ingredients. You need a 32gb Vag card to minimise hacking the contents about. It won't work with a standard SD card.
Reactions: n1kolaa
Not sure what you mean, but I had only private messaged the link I found to the MIB1 480 firmware update in case it was removed. Don't think I can edit my first post to add this URL:
It also seems to be here https://mibsolution.one/#/1/9/_pre MIB2/MSTD/SEAT (username & password = guest). The site has been very slow before though.
My backup of our 2014 Leon V4 maps is still here:
The 2023 maps that worked are P106_N60S3MIBS2_EU_NT (8V0060866S).7z on https://mibsolution.one/#/1/15/MSTD
im on right track but with mega limits
Yes you have to wait out the holds with the mega limits if you dont subscribe. It gets there in the end.
Look at me now ? need other parts to invest in. Its posibole to upgrade to mib2std with this display?
Well you have mib1 2023 maps now. A lot of people did invest in mib2 who had mib1 at the time. Circa 2015 and on you will find threads on here. The board sponsor sells mib2 standard kit upgrades. @East Yorkshire Retrofits but pass of whether the screen needs changing. The interest was Android Auto and Car Play in some quarters. There are little AliExpress boxes that give AA into an existing mib1. Some people do that route.
Mib2 maps may be coming to the end of their cycle of updates although as seen a mib1 map update was released 3 years after it had got to the end of it's cycle. Mib2 high is throught to go on beyond since Audi was fitting them into TTs well after 2020. That's been said by mib2 high Audi TT owners.
Depends what you want to do. This is a map update thread. Well done for getting the mib1 map update into you unit and firmware. I did say every body had achieved it so far using @Daz3d lead.
For one thing on your Skoda which I think you have you need the equivalent to the Seat 480 firmware. The Skoda guy had that so got it all working. The map file it self was on mibsolution.one but is knocking about on this thread. I think so anyhow. I set you the task to find it.
See the first few paragraphs to the resource here with pointers:
I mention the Skoda firmware that is equivalent that needs to be used. It appears the same mib1 workaround which had been illusive for years for Seat owners works on Skodas. Historically Skodas didn't need this workaround so you could just insert the map file as an upgrade. The map file is an Audi release but tinkering with the header locks it back into Seat or Skoda units so the unit isnt aware the maps have been updated. It then reads the updated maps.
In some instances it was found on Seat's you had to roll back to the previous release and lock onto that. Thats a mib trick that any previous map release will work. How mapcare works. So mapcare is fooled twice to make it work. The edit map reference is then the previous release. Least I think. You need to study @Daz3d posts and everybody else's since then on the subject. Daz3d didnt need to do that trick but others did. It was where their release was after Daz3d's was as I recall. So using elements of Daz3d old files kicked it off. Old files of Daz3d, new map file. The workaround plus the firmware update.
As I recommend buy a mib2 map card. Test with your existing maps on it. Then use the new mapcard for your project so you will always have your old working copy if things go wrong. It also avoids having to edit down as @Daz3d did. Removes one possible area of issue.
The firmware is fine then. Just tracking those posts. @Daz3d provided the links ... just got to hunt them down in the posts. I'm leaving that to you.
Working backup from this post
@Daz3d provided the missing bit. He's the guy that brought the working solution here.
I've done the work for you tracing back... look here:
You may still have to deploy the tricks of going back one release. As you read 7zip was an issue. I'd update your 7zip if it isn't or use the built in Windows 10/11 file manager one.
Hello guys, i have a problem with my multimedia on my Seat Leon 5F with factory MSTD_EU_SE_P2313, MU Version 0132, i tried to update the software version with rar file from mibsolution.one (MSTD_EU_SE_P5310 MU0480), everything was going well on the update but when 3 files left to overwrite all of sudden multimedia went black but not completly black and it stays like that all the time, when i try to restart it with holding power button it goes completply black and come with power again but still black and i can't do anything now, i checked it with obd11 and there is communication with 5F unit which i think is a good sign. i need your help if you have any solution...i just want to make it like it was before no need to update it, thank you in advance
As you obviously found out, you cannot jump from 01xx to 02xx, 04xx and so on.
Even though you have connection, the unit is now bricked.
I assume your best bet is someone with ODIS being able to write the correct software or then (don't ask me how) removing unit from car, building an interface that can write straight to the chip and downgrading the software via a computer, since you don't have access to the screen anymore to start an upgrade process.
Reactions: ak1_
Yes you need to seek help on the mib2 firmware thread
You are told n th times not to jump firmware trains. You can't as per above.
This thread is solely map files not firmware files. I believe you can open these units up and short a couple of pins out which de bricks it. You'll find instructions on the Internet. @East Yorkshire Retrofits provides a service of train jumping and has sorted peoples units out in the past where they have messed them up. Unfortunately the likes of Mr Fix with YouTube videos leads people into going up a dead-end.
Anyhow and conversation on mib2 firmware should be on that part of the board. The unit are like early computer so you write across the boot firmware code with the wrong train.
