Tell
Tell
@Tell - quick question - is there any way to fool the MIB2 to "mirror" what they say are "unauthorised" apps on your phone in Android Auto? Mirror link no longer supported on the Galaxy phones (mines an S9+), and the app isn't approved to show from Android Auto, but would really like to display VAG DPF app on-screen if at all possible. Failing that, do you know of any way to fool the phone into accepting MirrorLink, as it will not install any MirrorLink apk I download, even the Samsung Mirror Link version. Thanks.
Probably the old Apks are being blocked on the Android update cycle of versions. There is a way of sideloading old Apks via the developers menu and plugging in your device (Android phone) into your PC / laptop and installing it that way. I did that with some very old apps on Irish birds and Butterfly identification 😉. They hadn't been rewritten from Android 5. Into Android 14 and migrated to Android 15. They were definitely not rewritten for later versions of Android. Was an Irish person's pet project on identification. They get the same as us but less diversity so UK apps would work for identification...
I'll look the commands up and edit in later. Its ADB plus a specific command put in for the purpose which skips the block. This would be usefull where you have the old modified app, think it was Android Auto which people had that supported Mirrorlink. It is Samsung Galaxy fablets I use. Worth a try if you have something that worked but can't install on a newer version of Android.
It's this one:
Run the following command in your terminal/command line window:
adb install --bypass-low-target-sdk-block FILENAME.apk
From XDA forum. I guess it works for Android 15 as well. It's a more slick way than editting the manifest.
However if it's an older model than Android 14 you might have to edit the manifest. That fools it to think its a new app. That bypass command came in later to be helpfull to developers.
Reactions: DaveS
LeylandVCDS
591
355
Leyland, Lancashire
It's this one:
Thanks, I'll do some research, it's Android 10 on my phone
Jul 19, 2025
11
TrYED p94 for mstd
this is dbinfo from original card
PartNumber1="-----------"
PartNumber2="5G0919866E "
PartNumber3="5E0919866E "
PartNumber4="5F0919866E "
PartNumber="-----------"
ApplicationSoftwareVersionNumber="0034"
SystemName=" ECE 2013/14 "
p94 refuse to work
Tell
TrYED p94 for mstd
p94 refuse to work
That's mib1 you need to follow this
Follow people's success with this. Take a copy before you start off.
I referenced that in the resource:
In the end nobody to my knowledge hasn't got it to work. Eg. Everybody has had success eventually.
@Daz3d posts that one and after contain the ingredients. You need a 32gb Vag card to minimise hacking the contents about. It won't work with a standard SD card.
Reactions: n1kolaa
Jul 19, 2025
11
Not sure what you mean, but I had only private messaged the link I found to the MIB1 480 firmware update in case it was removed. Don't think I can edit my first post to add this URL:
It also seems to be here https://mibsolution.one/#/1/9/_pre MIB2/MSTD/SEAT (username & password = guest). The site has been very slow before though.
My backup of our 2014 Leon V4 maps is still here:
The 2023 maps that worked are P106_N60S3MIBS2_EU_NT (8V0060866S).7z on https://mibsolution.one/#/1/15/MSTD
im on right track but with mega limits
Jul 19, 2025
11
Yes you have to wait out the holds with the mega limits if you dont subscribe. It gets there in the end.
Look at me now 🫡 need other parts to invest in. Its posibole to upgrade to mib2std with this display?
